Create new Wizard
Highlighted
Amethyst
Create new Wizard
I would like to create a custom wizard. I copied the example and
renamed the jsp files to new names. I added the new names to the
actions.properties file and added an action for each of the wizard steps.
When I attempt to run the wizard, the error
"javax.servlet.jsp.JspException: Could not run doTag in WizardTag" is
returned.
Does anyone have any suggestions on how to fix this error?
Thank You,
Paul Hartwig
Sr. Application Developer, PLM Applications
Ingersoll Rand Climate Control Technologies
314 West 90th St
Minneapolis, MN 55420-3693
Email: Paul_Hartwig@irco.com
Highlighted
Create a new Wizard
I would like to create a custom wizard. I copied the example and renamed the jsp files to new names. I added the new names to the actions.properties file and added an action for each of the wizard steps. When I attempt to run the wizard, the error "javax.servlet.jsp.JspException: Could not run doTag in WizardTag" is returned.
Thank You,
Paul Hartwig
314 West 90th St
Highlighted
Create new Wizard
Paul -
This is more of a general error related to JSP tag libraries. Did you incorporate your own JSP tag library or write one yourself? If not, send me what you changed and I can help you look at it. You may of accidentally changed some OOTB PTC code and now it can not find the class file is also a possibility.
More about a doTag purpose wise:
