Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
As per the suggestions I received, I tried to create a new Vault by logging into DSMU but Intralink is throwing an error "Incorrect fileserver password.."
What password is this utility looking for… the administrator password to logon to the fileserver or the administrator password to logon to the dataserver?
