How can we automatically create a large EBOM from a large MCAD assembly . Please note the MCAD assembly is created in the Creo.
By default you need to open your CAD assembly from within the CAD application connected to Windchill and then do a save and check-in with the option of auto-associating parts.
This is the Out-of-the-box behavior, but your Windchill environment may be configured differently.
Doing it through the CAD application is mandatory for the following reasons:
