Creo View Adapters - publishing certain objects
BuddyHudson
To all Windchill 10.1 admins,
Is it possible to have have the Creo View Adapters publish only vertain objects?
I have a CAD worker that is publishing fine it is just getting backed up with so many parts when users check-in large assemblies. Sometimes there are 1500-2000 parts. Ahy way to not publish what has already been published if I dont want to?
Thanks in advance for your help,
Buddy Hudson
LoriSood
23-Emerald I
(To:BuddyHudson)
You can create a custom publish filter method to only publish objects that meet a specific criteria. For example, the following article gives an example of how to only publish EPM Docs at a particular lifecycle state:
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS98475
Additionally, you may want to take a look at this article for an explanation of the different filter method properties in the wvs.properties:
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS39455
Additional example methods can be found in the com.ptc.wvs.server.publish.EpmDocumentPublishFilters class in 10.1
LoriSood
23-Emerald I
(To:BuddyHudson)
dyadav
(To:LoriSood)
Please suggest best practice to publish Dxf and PDF by using Creo view adaptere and windchill 10.1
