Creo View Failed to load the file.
mastachef
The following message is the error I receive when trying to view a Windchill representation in Creo View:
"Failed to load the file. Check the Adobe Acrobat or Adobe installation."
My machine is currently running Creo View 3.1 M010 build 27. Is there anything I can troubleshoot?
1 ACCEPTED SOLUTION
14 REPLIES 14
TomU
(To:mastachef)
Viewing PDFs in Creo View also requires Adobe Acrobat or Adobe Reader to be installed locally.
BenLoosli
23-Emerald II
(To:mastachef)
Do you have Adobe Acrobat Reader loaded?
Is it the right version to run with CreoView 3.1?
Currently have Adobe Acrobat Reader 2017 Release 2017.011.30096 installed
TomU
(To:mastachef)
That's more than likely the problem.  Either roll back to an older version of Reader or upgrade to a newer version of Creo View.
You may also want to vote for this product idea:
https://community.ptc.com/t5/Addtl-Creo-Ideas/Embed-PDF-viewer-within-Creo-View/idi-p/476631
TomU
(To:mastachef)
Here's a link to older versions if you need it:
https://supportdownloads.adobe.com/product.jsp?platform=windows&product=10
mastachef
(To:TomU)
Thank you for your suggestions. I am going to check out our options regarding an upgrade to Creo View or downgrade Adobe Reader.
There was also an adapter I saw (Creo View PDF viewer). I am wondering if that is another options.
TomU
(To:mastachef)
Creo View Adapters are used by the Windchill CAD workers for automated publishing.  They create the data for Creo View to use.
BenLoosli
23-Emerald II
(To:TomU)
CreoView adapters are specific to certain releases of Windchill. Be sure that you have the right combination of Windchill, CreoView Adapters, CreoView and Adobe Acrobat.
TomU
(To:mastachef)
Here is the version you need installed for Creo View 3.1 M010:
"PDF viewing supported with Adobe Reader X (10.x), XI (11.0), DC"
mastachef
(To:TomU)
'Failed to load the file. Make sure that the registry entry of Adobe Acrobat or Adobe reader points to the correct installation. If the registry entry is correct, and re-installing Adobe Acrobat or Adobe Reader, and then restart'
Performed an uninstall and re-install of both application to no avail.
 https://www.ptc.com/support/-/media/00548DEEA08F4097A946C928F3E090DF.pdf?sc_lang=en
Should I/Can I upgrade to Creo View 5.0 per the chart? I cannot seem to find the correct version of Creo View which will run successfully with Windchill.
The suggested page URL gives a 404 error.  Do you still have whatever it was in either a descriptive text form or the PDF?
I am having this issue as well. I have tried everything. It works on one of my PC's but I can't get it to work on the other.
Previously it would ask to install the adobe plug in and I would need to gain admin access to do it. Now I get the "failed to load the file" message every time I try to open a PDF.
My apologies.
The solution is to ensure that the version of Creo View, Adobe and Windchill are all compatible. In my case, I was able to upgrade my Adobe product from Adobe Reader to Adobe Acrobat Pro DC. Once I did that, I was able to view and edit representations.
Attached is the software compatibility matrices I used to figure out my configuration
