We're running into an issue with one of our systems where when trying to register our server with the correct location, Creo keeps throwing the "Invalid server location" error. The location is correct. One thing we noticed was that the .cache2008 folder in AppData/Roaming isn't getting created.
There's no Environmental Variable settings changing the cache location and at this point we're stumped. Any suggestions? We can try a re-install... but aside from that what else could be causing the cache folder not to get created?
