CreoView Install
I am trying to install CreoView Adapters 7.1.1.0 on my Windchill 11.1. M020 CPS20 server which is running on Windows Server 2016. The matrix says I need the Desktop Experience and I checked with IT and they say they installed it that way.
However, when I run the proe2pv_config.exe, the Setup button is grayed out. I also tried 8.0.0.0.
Any suggestions before I contact PTC support?
BenLoosliAnswer
Unchecked Create proeworker and the Setup became selectable, saved it and Recipe Editor is selectable.
TomU
No issues installing it on my server(s).  Does your user account have admin rights? Try 'Run as Administrator'?
BenLoosli23-Emerald IIIAuthor
Setup and Recipe Editor are greyed out even when I 'Run as Administrator'.
I am wondering if IT did not build the systems with Desktop Experience.
TomU
If you're logged into the computer and looking at a desktop, then desktop experience is installed.  Without it everything has to be done from a console (command prompt.)
