Hi @lzwheel
CreoView is standalone application and needs the file locally, so it is downloaded to the windows temp location.
I don't think so you can prevent this behavior.
You can restrict the download operation by ACL access, but it is useless if the user should work with the file.
PetrH
Hi @lzwheel
PetrH
My purpose is that the user can only view the document through CreoView, but not get the original document. I disabled the download function of windchill and the save function in CreoView, but found that the original file can be obtained from the cache. Is there any other solution to meet this requirement, so as to ensure that the original file is not obtained by the user ?
