We are happy to announce the new Windchill Customization board! Learn more.
Custom Action - handle to all selected rows
MarkBohannon
7-Bedrock
I am working on a custom action where the user can select one or more EPM Documents and start the action.  My implementation is currently using the request parameter to grab the oid’s/soid’s of the selected objects however it only works when the user selects 8 or less items.  Is there another way to get the list of all the selected item rows at the time the custom action is selected?  If so, can you provide some guidance?
 Current method used in popup JSP
ids = request.getParameterValues("soid") or id = request.getParameter("oid")
Mark Bohannon
Lenovo
Florent
(To:MarkBohannon)
Hi Mark
I've never noticed this behavior. However, you can perhaps have a look on OOTB JSP (in codebase/netmarkets/jsp/...) ?
I've been able to find this (<WT_HOME>/codebase/netmarkets/jsp/object/editMultiObjects.jspf)
ArrayList oidList = cb1.getSelectedOidForPopup();
But there could be a better way. I invite you to look at the Customizer Guide.
Florent
Florent ROUSSEL
www.4cad.ca
Florent
(To:MarkBohannon)
Hi Mark
Florent
Florent ROUSSEL
www.4cad.ca
Thanks for the information.  I had found a reference to the NmCommandBean in the documentation however I did not know how to implement.  I ended up usin
// Code in /ext/publishDocuments/jsp/publishPopup.jspf
sessionBean.setDoneCB(false);
NmCommandBean cb1 = new NmCommandBean();
cb1.setInBeginJsp (true);
cb1.setOpenerCompContext (request.getParameter("compContext"));
cb1.setOpenerElemAddress (NmCommandBean.convert(request.getParameter("openerElemAddress")));
cb1.setCompContext (NmCommandBean.convert(request.getParameter("compContext")));
cb1.setElemAddress (NmCommandBean.convert(request.getParameter("elemAddress")));
cb1.setSessionBean (sessionBean);
cb1.setRequest (request);
cb1.setResponse (response);
cb1.setOut (out);
cb1.setWtcontextBean (wtcontext);
cb1.setContextBean (nmcontext);
cb1.setSelected(oidList);
<%@ include file="/ext/publishDocuments/jsp/publishPopup.jspf" %>
cb1.getSelected().get(i) // to retrieve each id - I iterated through the list
