Custom Attributes to be published to the Distribution target
svs
2-Explorer
2-Explorer
Guys ,
I have created a Distribution Target (File Type) to output the BoM Information as XML . But I am not able to pusblish the custom attributes that i have on the WTPart which is displayes in the BoM . How can I publish them as XML to the distribution target ? Thanks in advance.
psampath
7-Bedrock
(To:svs)
you will have to add those attributes to the esiresponsemetainfo.xml file. Then open the distribution target and give the path of the new metainfo file. Restart windchill and you will be able to see the iba's in the output.
