Hi Guys,
Can we get a delete option in which I highlighted in image. Please find the below.
Amir
That is a workspace. I think you want remove. That will remove items from your workspace. If the item has not been uploaded, it will be "deleted". You can also delete from Search Results very easily.
Thanks for the replay, Mr. Avil,
Sorry that image is wrong one, I want to add a few options like a delete, revise and etc.
Aj
It depends on if you have the rights to delete. You have to talk to your administrator.
You can also look in the Actions drop-down menu there.
You are asking to just move them on to the bar and expose them easier?
You need to customize the customActionModel.xml
../codebase/config/actions/customActionModel.xml
You add need to add a right menu and set the shortcut to yes for specific menu options.
for folder menu it is
folderbrowser_toolbar_actions
<model name="folderbrowser_toolbar_actions">
<description>Folder browser toolbar actions menu for all Folders.</description>
<submodel name="folderbrowser_toolbar_open_submenu" />
<action name="customLaunchMatrixEditorWizard" type="productfamily"/>
<action name="separator" type="separator" />
<submodel name="folderbrowser_toolbar_new_submenu" />
<action name="list_cut" type="object" /> <!-- Cut -->
<action name="list_copy" type="object" shortcut="true" /> <!-- Copy -->
<action name="pasteAsCopy" type="saveas" /> <!-- Paste (for Product/Library/Org/Site) -->
<action name="fbpaste" type="object" /> <!-- Paste -->
<action name="CONTAINERMOVE" type="pdmObject" /> <!-- Move -->
<action name="multiObjectCheckIn" type="wip" /> <!-- multiObjectCheckIn -->
<action name="multiObjectCheckOut" type="wip" /> <!-- multiObjectCheckOut -->
<action name="PAGERELOADINGMULTICHECKOUT" type="folder" /> <!-- Check out to Workspace -->
<action name="multiObjectUndoCheckout" type="wip" /> <!-- multiObjectUndoCheckout -->
<action name="editMultiObjects" type="object" /> <!-- Edit Multiple Objects -->
<action name="MULTIREVISEITEMS_FROMFOLDERS" type="pdmObject" /> <!-- Revise -->
<action name="launch" type="massUpdate"/>
<action name="route" type="workflow" /> <!-- Route -->
<action name="WFMULTISAVEAS" type="folder" /> <!-- Save As -->
<action name="MULTIRENAME" type="folder" /> <!-- Rename -->
<action name="SETSTATE_FROMFOLDERS" type="pdmObject" /> <!-- Set State -->
<action name="export" type="object" /> <!-- Export -->
<action name="cadmultiexport" type="object" /> <!-- Export -->
<action name="list_delete" type="object" shortcut="true"/> <!-- Delete -->
<action name="batchPrint" type="wvs" /> <!-- Batch Print -->
<action name="WFADDTOWORKSPACE" type="folder" shortcut="true" /> <!-- Add to Workspace -->
<submodel name="folderbrowser_toolbar_addto_submenu" />
<action name="sendToPDM" type="sandbox" /> <!-- Send to PDM -->
<action name="convertToShareTB" type="sandbox" /> <!-- Convert to Share -->
<action name="sandboxCheckoutShareMultiSelect" type="object" /> <!-- Convert to PDM Check-out -->
<action name="sandboxUndoCheckout" type="object" /> <!-- Undo PDM Check-out -->
<action name="manageIdentityConflicts" type="sandbox" /> <!-- Manage Identity Conflict -->
<action name="SBUpdatePrj" type="sandbox" /> <!-- Update Project -->
<action name="updateShareMultiSelect" type="sandbox" /> <!-- Update Selected Shares -->
<action name="removeShareTB" type="object" /> <!-- Remove Share -->
<submodel name="folderbrowser_toolbar_compare_submenu" />
<action name="ConfigLinksCollectorDialog" type="folder" /> <!-- Config Links Collector Dialog -->
<submodel name="folderbrowser_toolbar_process_submenu" />
<action name="downloadDocumentsToCompressedFile" type="document" /> <!-- Download Documents to Compressed File -->
<action name="createImportJob" type="ixb"/> <!-- Import from Spreadsheet -->
<submodel name="folderbrowser_toolbar_exportlisttofile_submenu" />
<submodel name="folderbrowser_toolbar_requirements_submenu" />
<action name="multiObjManageSecurity" type="accessPermission"/>
<action name="MULTIEDITSECURITYLABELS" type="object"/> <!-- Manage Security -->
<action name="createSubscription" type="subscription" /> <!-- Subscribe -->
<action name="separator" type="separator"/>
<action name="track_new_work_table" type="resourceAssignment" /><!-- Track new Work against subject of deliverable-->
<action name="new_plan_activity_table" type="planActivity" /><!-- New Plan Activity against subject -->
<includeFilter name="ActionFilterOnProject2State" />
</model>
restart windchill and the button will be available in the ribon menu.
PetrH
Good Morning Mr. Petr, Thanks for the replay and apologize for delayed in response.
After making changes in customActionModel.xml, it will appear in the action button menu or as highlighted in the below image.
I want it highlighted.
AJ
