I really don't know why they (QA) want this when you can look at in the browser and see the "Last Modified" date, but they want it on our documents.
The fields I can see are Last Saved Date, Last Saved By and Last Printed. MS Office has a Saved Date but the just changes when you save it.
Is there away to get this without customizing the DTI Framework.
Many Thanks,
Mike Pinkney
CAD/Windchill Administrator
Triple Ring Technologies, Inc.
In Reply to Mike Pinkney:
Many Thanks,
Mike Pinkney
You didn't mention what Windchill release you are using; info below is valid for Windchill 10.x.
The typical Windchill attributes such as the one you are interested inare available OOTB via DTI for insertion as a document property field in MS Office applications.
Simple how-to: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS45089
From here you can test various actions, like "Info Page Test", "Refresh Attributes Test, etc.
Hope that helps!
