You did not specify which version of Creo View Adapters you are using but it could be this issue fixed in Creo View Adapters 8.1:
Hi @ravimane27
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Windchill looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Thanks Catalina for your resposne.
Yes issue is generic with all drawings where it creates dxf file and its output log file which gets zip and shown in Additional Files as shown below
Yes I am using custom publishing rule as below
Thanks and Regards,
Ravindra Mane
Thanks Mr Jones, I was using Creo Adapter 7.1 and after installing 8.1 issue is resolved. Thanks a lot and have a great day.
Ravindra
