Database error - invalid name pattern
Highlighted
Newbie
I am getting the following database error whenever I create a second instance in the same Oracle server. It seems to be a configuration issue. I got the same error in three different servers and yet I couldn't figure out the actual problem. Any info would be greatly appreciated.
Prathap
Mon 7/28/08 11:52:05: main: INFO : wt.pom.statementCache - WTConnection(): statementManager=wt.pom.StandardCacheStatementManager
Mon 7/28/08 11:52:05: main: INFO : wt.pom.properties - Connection: datastore=Oracle(Oracle Database 10g Release 10.2.0.1.0 - Production) jdbcVersion=10.2 driver=Oracle JDBC driver(10.2.0.3.0) driverVersion=10.2
Mon 7/28/08 11:52:06: main: ERROR : wt.pom.jdbc - *** SQLException caught ***
Mon 7/28/08 11:52:06: main: WARN : wt.pom.jdbc - SQLState: null
Mon 7/28/08 11:52:06: main: WARN : wt.pom.jdbc - Message: invalid name pattern: WTUSER.FTCELLINFO
Mon 7/28/08 11:52:06: main: WARN : wt.pom.jdbc - ErrorCode: 17074
Mon 7/28/08 11:52:06: main: Testing for lost connection: errorCode=17074 checkCodes=[3114, 12571, 17002, 17410, 17401, 1012, 17008, 3113]
Mon 7/28/08 11:52:06: main: wt.ufid.UfidException: wt.pom.DatastoreException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: wt.pom.ConnectionException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: Nested exception is: java.sql.SQLException: invalid name pattern: WTUSER.FTCELLINFO
Mon 7/28/08 11:52:06: main: Nested exception is: wt.pom.DatastoreException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: Nested exception is: wt.pom.ConnectionException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: Nested exception is: (wt.pom.pomResource/0) wt.pom.PersistenceException: A persistence error occurred. System message follows:
Mon 7/28/08 11:52:06: main: at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
Mon 7/28/08 11:52:06: main: at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:146)
Mon 7/28/08 11:52:06: main: at oracle.jdbc.oracore.OracleTypeADT.initMetadata(OracleTypeADT.java:463)
Mon 7/28/08 11:52:06: main: at oracle.jdbc.oracore.OracleTypeADT.init(OracleTypeADT.java:362)
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.initPickler(StructDescriptor.java:317)
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.<init>(StructDescriptor.java:281)
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.createDescriptor(StructDescriptor.java:192)
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.createDescriptor(StructDescriptor.java:161)
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.createDescriptor(StructDescriptor.java:130)
Mon 7/28/08 11:52:06: main: at wt.pds.oracle81.OracleStatementParameterFactory.getStructType(OracleStatementParameterFactory.java:286)
Mon 7/28/08 11:52:06: main: at wt.pds.oracle81.OracleStatementParameterFactory.initializeStruct(OracleStatementParameterFactory.java:191)
Mon 7/28/08 11:52:06: main: at wt.pds.StatementParameterFactory.initializeTypes(StatementParameterFactory.java:298)
Mon 7/28/08 11:52:06: main: at wt.pds.oracle81.OracleStatementParameterFactory.initializeTypes(OracleStatementParameterFactory.java:96)
Mon 7/28/08 11:52:06: main: at wt.pds.SQLDatabasePds.initializeConnection(SQLDatabasePds.java:1513)
Mon 7/28/08 11:52:06: main: at wt.pds.OraclePds.initializeConnection(OraclePds.java:483)
Mon 7/28/08 11:52:06: main: at wt.pom.WTConnection.connect(WTConnection.java:141)
Mon 7/28/08 11:52:06: main: at wt.pom.WTConnection.<init>(WTConnection.java:105)
Mon 7/28/08 11:52:06: main: at wt.pom.PersistentObjectManager.connect(PersistentObjectManager.java:303)
Mon 7/28/08 11:52:06: main: at wt.pom.POMHandler.getConnection(POMHandler.java:105)
Mon 7/28/08 11:52:06: main: at wt.method.MethodContext.getConnection(MethodContext.java:1650)
Mon 7/28/08 11:52:06: main: at wt.pom.PersistentObjectManager.getUserConnection(PersistentObjectManager.java:336)
Mon 7/28/08 11:52:06: main: at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1097)
Mon 7/28/08 11:52:06: main: at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1007)
Mon 7/28/08 11:52:06: main: at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:4543)
Mon 7/28/08 11:52:06: main: at wt.fc.StandardPersistenceManager._find(StandardPersistenceManager.java:4598)
Mon 7/28/08 11:52:06: main: at wt.fc.StandardPersistenceManager.find(StandardPersistenceManager.java:1594)
Mon 7/28/08 11:52:06: main: at wt.fc.StandardPersistenceManager.find(StandardPersistenceManager.java:623)
Mon 7/28/08 11:52:06: main: at wt.fc.PersistenceManagerFwd.find(PersistenceManagerFwd.java:212)
Mon 7/28/08 11:52:06: main: at wt.ufid.FederatableServerHelper.getRepositoryFromDB(FederatableServerHelper.java:1162)
Mon 7/28/08 11:52:06: main: at wt.ufid.FederatableServerHelper.getRepository(FederatableServerHelper.java:231)
6 REPLIES 6
Highlighted
Add / Update this property in site.xconf
wt.pom.recoverableConnectionCodes
include this error code along with a list of other error codes as shown
below.
<property name="wt.pom.recoverableConnectionCodes" overridable="true"&lt;br"/>
targetFile="db/db.properties"
value="28,1012,17002,17008,17140,17410,3114"/>
Hema Jatla | Datafrond LLC - <">http://www.datafrond.com>
hjatla@datafrond.com | Fax: +1 480.247.5908
Highlighted
Hi Hema,
Thanks for the input. This error is not going away even after adding
that error code to the db.properties as you suggested.
Prathap
Mon 7/28/08 12:42:36: main: INFO : wt.pom.properties -
wt.pom.connectionMonitorSleepInterval= 10
wt.pom.lostConnectionCodes=
1012,3113,3114,12571,17002,17401,17008,17410
wt.pom.recoverableConnectionCodes= *
28,1012,17002,17008,17401,17410,17412,1400,1403,3106,3114,12571,3113,17074*
wt.pom.freeConnectionImmediate= false
wt.pom.maxIdleStatementCaches= 0
wt.pom.jdbc.driver= oracle.jdbc.driver.OracleDriver
wt.pom.jdbc.url= jdbc:oracle:thin:
Highlighted
Hi Prathap,
Try the property this way
<property name="wt.pom.recoverableConnectionCodes" overridable="true" targetfile="db/db.properties" value="17002,0"/">
Let me know if this works
Alexius C. Chukwuka
IT Analyst, PDP Systems
John Deere Power Systems
Product Engineering Center
Highlighted
RE: Database error - invalid name pattern
Hi Alex,
Thanks for your input. That property also didn't seem to work either. I tried many variations of it with no success.
Prathap
Mon 7/28/08 13:34:27: main: INFO : wt.pom.properties - wt.pom.lostConnectionCodes= 1012,3113,3114,12571,17002,17401,17008,17410
Mon 7/28/08 13:34:27: main: INFO : wt.pom.properties - wt.pom.recoverableConnectionCodes= 17002,0
Mon 7/28/08 13:34:36: main: ERROR : wt.pom.jdbc - *** SQLException caught ***
Mon 7/28/08 13:34:36: main: WARN : wt.pom.jdbc - SQLState: null
Mon 7/28/08 13:34:36: main: WARN : wt.pom.jdbc - Message: invalid name pattern: WINDCHILL.INSTANCE_ROW
Mon 7/28/08 13:34:36: main: WARN : wt.pom.jdbc -ErrorCode: 17074
Mon 7/28/08 13:34:36: main: Testing for lost connection: errorCode=17074 checkCodes=[3114, 12571, 17002, 17410, 17401, 1012, 17008, 3113]
Mon 7/28/08 13:34:36: main: wt.ufid.UfidException: wt.pom.DatastoreException: A persistence error occurred. System message follows:
Mon 7/28/08 13:34:36: main: wt.pom.ConnectionException: A persistence error occurred. System message follows:
M
To: -<
Subject: [solutions] - Database error - invalid name pattern
Prathap
Mon 7/28/08 11:52:06: main: at oracle.sql.StructDescriptor.(StructDescriptor.java:281)
Mon 7/28/08 11:52:06: main: at wt.pom.WTConnection.(WTConnection.java:105)
Highlighted
did you run the create_ddl_wt.sql after you created the instance.
Rajesh
In Reply to:
Prathap
Rajesh Balasundaram
Highlighted
Hi Rajesh,
I am importing an exported 9.0 schema and it will create the
necessary tables. I don't have to run the create_ddl_wt.sql and the import
fails if I run this script first.
Prathap
On Mon, Jul 28, 2008 at 1:55 PM, Rajesh Balasundaram <
> Regards,
> Rajesh
> In Reply to:
> Thanks,
> Prathap
> Mon 7/28/08 11:52:06: main: WARN : wt.pom.jdbc - *Message: invalid name
> pattern: WTUSER.FTCELLINFO*
> Mon 7/28/08 11:52:06: main: WARN : wt.pom.jdbc - *ErrorCode: 17074*
