Dealing with Reference Designators (code snippet)
Aquamarine
Reading
private String getRefDesignator(WTPartUsageLink link)
QueryResult
result=OccurrenceHelper.service.getUsesOccurrences(link);
while (result.hasMoreElements())
Object o=result.nextElement();
if (o instanceof PartUsesOccurrence)
PartUsesOccurrence puo=(PartUsesOccurrence)o;
list.add(puo.getName());
Writing
private void createRefDesignators(WTPartUsageLink link, String
designators) throws WTException, WTPropertyVetoException
StringTokenizer st=new StringTokenizer(designators,",");
while (st.hasMoreTokens())
String refDesignator=st.nextToken();
PartUsesOccurrence
occurrence=PartUsesOccurrence.newPartUsesOccurrence(link);
occurrence.setName(refDesignator);
OccurrenceHelper.service.saveUsesOccurrenceAndData(occurrence,null);
Sorting
The ref designators require a custom sort so instead of "C1,C10,C11..."
we get "C1,C2,C3 ...".
public int compare(Object obj, Object obj1)
String s1=(String)obj;
String s2=(String)obj1;
try {
boolean b1=false;
boolean b2=false;
String s1a=";
String s2a=";
int l= (s1.length() > s2.length() ? s1.length() :
s2.length());
for(int i=0;i<l;i++)<br/>
if ((!b1)&&(Character.isDigit(s1.charAt(i))))
b1=true;
s1a=s1.substring(0,i);
if ((!b2)&&(Character.isDigit(s2.charAt(i))))
b2=true;
s2a=s2.substring(0,i);
if ((b1)&&(b2))
break;
if (!(s1a.equals(s2a)))
return s1a.compareTo(s2a);
Integer s1n=new Integer(s1.substring(s1a.length()));
Integer s2n=new Integer(s2.substring(s2a.length()));
return s1n.compareTo(s2n);
catch (Exception e)
return s1.compareTo(s2);
Re: Dealing with Reference Designators (code snippet)
you should rather have a look to the Windchill interface wt.part.ReferenceDesignatorSet.
For example: getting all sorted occurence names from the value of the ReferenceDesignator:
ReferenceDesignatorSet refDesSet = new DefaultReferenceDesignatorSet()refDesSet.initialize(refDesignator); final List<String> listOfReferenceDesignator = refDesSet.getExpandedReferenceDesignators();
It really makes sense to use the Windchill implementation because the format for the reference designators can be modifed with WTPreference (at least with WT11.0)
