Has anyone found a way to set the default Bind DN for OpenDJ? It defaults to "CN=Directory Manager" and I would like it to default to "CN=Manager" instead.
You can simply add the alias "CN=Manager" to the default one "CN=Directory Manager" (or the reverse).
It's in the config.ldif file (<OpenDJ_HOME>/config/config.ldif). Look for "Directory Manager" and add the required line:
ds-cfg-alternate-bind-dn: cn=Directory Manager
ds-cfg-alternate-bind-dn: cn=Manager
Restart OpenDJ and you will be able to use either one.
I would like to know how to do that too. We can set the Bind DN to "CN=Manager" during OpenDJ installation, but the login GUI continues to defaults "CN=Directory Manager".
I found this: The default value for the bind DN is for the root DN user, cn=Directory Manager.
https://docs.oracle.com/cd/E19450-01/820-6169/to-start-the-controlpanel.html
We set Bind DN to "CN=Manager", so would it be a step to set the root DN user to "cn=Manager"?
I already have "ds-cfg-alternate-bind-dn: cn=Manager" in the config.ldif file and I am able to login as cn=Manager. The issue is that when I launch control panel the login GUI defaults to "cn=Directory Manager" for the Bind DN and I would like it to default to "cn=Manager" so that I don't have to change it each time I launch.
That's the whole purpose of this: you don't have to change it each time.
Let it to "cn=Directory Manager". I don't see the point to change it since it's the same account.
Thank you for the alternative approach. It gets us past having to hack the OpenDJ username each time.
As you said, I had to ensure both lines were in the config.ldif file. If a 'ds-cfg-alternate-bind-dn' entry doesn't exist, it can't be used as a login.
dn: cn=Directory Manager,cn=Root DNs,cn=config
cn: Directory Manager
Then I needed to restart OpenDJ before I could use 'cn=Directory Manager' username with the 'cn=Manager' password.
This screen capture just confirms above - easy way to know that this has been done.
One sees this once the control panel has been launched.
