Default Request Priority on a Change Request
ArronCochran
Does anyone know where the location is to change the default value for the request priority on a Change Request? I appreciate any help that can be provided.
Arron
It should be under where all the resource bundle files are stored. Need a more technical specific answer, reply back and I'll dig it up for you. Do you know how to build it, once you make the changes?
Sent from my Verizon Wireless BlackBerry
Thanks for the info. I was able to find the file and found the field to change. However, I am not that familiar with how to build it once the change has been made. Can you offer any suggestions?
Thanks again,
Arron
I'm assuming that you need to change a resource bundle entry and select
one to be the default value.
from a Windchill shell type the command
> enumcustomize
after you make the changes and save you'll need to run the next two
commands and then restart Windchill.
> ant -f bin/tools.xml bundle_custom -Dbundle.input=registry
> ant -f codebase/MakeJar.xml custUpdate
Steve D.
> Thanks again,
> Arron
