Hi
my view is that PDM unit should be the same than ERP unit to start with.
So if you have something in Each, or Liter in PDM it should be the same in ERP.
ERP will surely also manage many other needs for instance for sales team you may need alternative unit of measure.
For instance, your PDM is in SI when you transfer to ERP, I would expect that whatever is created as master data will also be in SI but for sales in the US (as an example only 🙂 ) to work quickly and discuss with customer, they may need to see imperial units. This is only a conversion/translation at the ERP level which does not change the master data.
As for Rolls, Bags, Cartons. to me these are not unit of measure. They are, as SAP call them, material.
Your BOM will contain metalic parts but also a carton for the packaging for instance. Here we talk about type and not UoM for rolls, bags, carton etc....
As you said, you can configure Windchill to have more or less or different UoM than those provided per default per PDMLink.
Also how can you calculate total weight if you have a mixture of UoM.
For instance you have parts in kg, which are put in a carton but the unit of your carton is carton ?
Hope this helps
Best regards
following this topic that might be already outdated, the answer of 'cc-2' above is not fully correct. Rolls, Bags, Cartons etc. as packaging materials are related to ERP alternative units of measure. For example you can specify that in total 8 pieces of your product fits into one carton. Example:
- Base unit of measure: each (or piece in ERP)
- alternative unit of mesure (AuM): carton
- numerator/denominator: 1/8
My question: I recognized that MPMLink's mPSE (10.2 M030) provides AUM, numerator and denumerator - but I could not find them in the PTC global attribute list. Are these depreciated attributes?
Thanks!
