Default Units for quantity
FrankMenendez
After following PTC's process for adding several custom units of measure (UOM) for quantity to the wt.part.QuantityUnitRB , we have found that the defaultValue key is ignored. We want the default value set to true for 'each' - which is the default value out of the box. However, we have one UOM that is only two letters in length, and the system is making that the default value, regardless of the setting for the defaultValue key.
Has anyone else experienced this? And if so, do you have a solution you can share?
PTC is currently investigating the issue.
Thanks in advance
This e-mail (including any attachments) is confidential and may be legally privileged. If you are not an intended recipient or an authorized representative of an intended recipient, you are prohibited from using, copying or distributing the information in this e-mail or its attachments. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete all copies of this message and any attachments.
Thank you.
StevenKo
(To:FrankMenendez)
run enumCustomize
browse to wt.part.QunantityUnitRB, see if you can switch Default Vaule from UI.
if it doesn't work, check Windchill\wtCustom\wt\part\QuantityUnitRB.rbInfo
you could have defaultValue=true set by accident.
rebuilt resourcebundle after update
ResourceBuild wt.part
