Hi Everyone
I was thinking on what would be the easiest solution to grant access for external users by reading an attribute from LDAP or put a users into a specific group.
I'm not really an expert on Apache but is it possible to configure the app-windchill-auth.xconf to check if the user have an attribute or if it's in a group or allow the access using the internal.com domain and than using a satisfy any?
If you do have any other idea or you can help me on that I appricite for that.
Erik,
take a look at this discussion and if you look also at the right middle of the page you can find some other discussion linked to your request.
http://communities.ptc.com/message/247894#247894
Hello
I know this, I have found it already but here they are talking about restrict users to access the system and not care about from which network they are coming from. If the satisfy any won't work than I need two kind of auth for external and internals based on the domains where they are coming from.
