Delete FTA Results?
ptc-4696404
Delete FTA Results?
I'm trying to get some simple results from my fault tree, however everytime I run it, instead of giving me the results for what I just ran (12 data points when I request 12), it appends the jsut run simulation onto the existing results (adds 12 data points to the existing 1000s, so I end up with x+12). I assume that when I run the FTA, the "removing existing results" function isn't working.
Is there any way to manually delete results?
Hi Jack, would you be able to contact me outside of this thread? Thanks -
