Hi @GK_10890476
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Try using the command line utility. You can delete items out of the queue more easily using this than you can through the Windchill UI for queues. See PTC article on how to use it:
Hi @GK_10890476 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
This is a typical problem with the WVS publish queues as the Windchill queue waits for an external event (the CADworker), and if this communication is missed the job and the queue get stuck.
Please see https://www.ptc.com/en/support/article/CS37569 for the handling and troubleshooting WVS publishing queues.
Michael
