I am stuck with deleting objects due to the following error:
Referential integrity violations occurred for this operation: ... Object "EPMDescribe Link - wt.epm.structure.EPMDescribeLink:37206516" references the object "wt.epm.EPMDocument:37180131" that was removed from the system.
Any hints how to proceed?
Thank you in advance for your support!
Best regards
Chris
It seems like an EPM Document (CAD document) was deleted from the system but the link back to the WT Part was not. (Not sure how that happens...) I wonder if deleting the WT Part would correct the problem.
https://www.ptc.com/en/support/article?n=CS23768
https://www.ptc.com/en/support/article?n=CS292752
Hello Chris,
Were you able to fix the above error while Deleting EPMDocument?
Br,
Ganesh
