Deleting object from Commonspace
Hi ,
When I am trying to delete objects from commonspace , first it takes
some time and then pops up error message window showing the
following error. I have tried with shift+delete also.
I have restarted the dataserver also.
"This error message has internal usage only.
It should be never put into stack.
Please check the online knowledge database at www.ptc.com
and/or contact Technical Support."
So what could be the reason.
Regards
Pankaj
