Dependency creation with Automation Interface (AddDirected ) Windchill Modeler
AS_12004554
2-Explorer
Version: Windchill Below 11.0
Use Case: The goal is to generate the model automatically with VBS API based on the text input, The model contains many Full ports, which are generated automatically. (Done) Every full port shall be connected to the same FlowPort with Dependency (Abstraction). Can you please give a hint how to do it?
Description:
How to generate the dependency (abstraction) from the flow port to the full port?
After this the stereotype shall be applied to the Abstraction.
Hi @AS_12004554,
Thank you for your question!
Best regards,
Catalina
PTC Community Moderator
PTC
