Has anybody implemented Desktop integration with SSO authentication. Our desktop integration is not taking siteminder for authentication.
Please suggest.
Sitanshu
I have tried to implement DTI with SSO authentication with Windchill 10 M020, but we did not managed to get it work. Configuration needs to support both FORMS and BASIC authentication. The issue with DTI and numerous other client side integrations we have is that we are using a web service enablement. Since FORMS based authentication is not standards based these clients are receiving an improper response from SiteMinder.
There might be a possible solution for this issue in Windchill 10.1. Because itsupports for Forms Based Authenticationand I can see from documentation (Windchill 10.1 help center)that there is also instructions how to configure DTI with Form-Based Authentication. In theory there should be a tools in place what is needed to get siteminder authentication work with DTI. Unfortunately I have not had possibility to test it yet in practice.
Marko
