Did anyone tried installing Windchill 13.0.2.x on RHEL9.2 ?
KV_12355386
6-Contributor
Version: Windchill 13.0
Use Case: When Launching PSI installer, the Next button is faded.
Description:
RHEL 9.2
Windchill Version 13.0.2.5
Java : 17.0.11 or 17.0.15
When we launch the PSI installer, The Next button is faded and i dont see any loggers captured under /tmp.
The problem is due to the file /etc/issue is empty.
Next Steps:
1> Rename the /etc/issue file, e.g: mv /etc/issue /etc/issue_backup0704
2>Re-run the test tool: java -cp . PlatformTypeTest
3>If you can run the test tool successfully without exception and get something like below, then you should be able to run PSI:
       **** PT getcurrentOS: Linux
       **** PT getVersion: REDHAT9
       ******It is not Centos8 *****
 Please let me know the result.
30 REPLIES 30
Yes but I installed 13.0.2.4 if that matters but I am using RHEL 9.2. I assume you've retried and it stops at the same spot? There should be some logs. Checking my notes, I did not use the default temp folder (/tmp). I mapped it to another folder with larger space:
https://www.ptc.com/en/support/article/CS178146?source=search
https://www.ptc.com/en/support/article/CS408865?source=search
Are you running SELinux?
/tmp has 14GB free space.
I even tried mapping it to different directory /opt/ptc/tmp, here as well the same issue.
export _JAVA_OPTIONS="-Djava.io.tmpdir=<new tmp location>"
Is your /staging_software a local physical folder or a mounted remote folder? If it is a remote folder, it might be due to the network latency. Make sure the installer has enough permission on the folder.
KV_12355386
6-Contributor
(To:Jimwang)
software is in local drive but not in remote folder.
Make sure the installer account has enough permission (at least R+E) on the Installation software package folder and has (W+E) permission on the tmp folder. Can you share a screenshot of the command (ls -lt) for the tmp folder and the Installation software package folder ?
Another option is to try to re-download the installation software package to exclude the software package itself issue.
KV_12355386
6-Contributor
(To:Jimwang)
Removed screenshot considering the security reasons
i did download the software again, but still the issue persist.
wcadmin@scllda0436 MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle]$ ./setup.sh
/usr/bin/which: no java in (/home/wcadmin/.local/bin:/home/wcadmin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin)
readlink: missing operand
Try 'readlink --help' for more information.
dirname: missing operand
Try 'dirname --help' for more information.
Starting: /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/Disk1/InstData/GenericUnix/NoVM/setup.bin LAX_VM /opt/ptc/app_13.0/Java/bin/java
Starting installer in the background.  Please wait...
[wcadmin@scllda0436 MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle]$ No of blocks of size 8192 to extract for custom unix file : 4
Extracting locale bundle from /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/Disk1/InstData/GenericUnix/NoVM/setup.bin to /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/custom_padded ...
Extracting done, exit code = 0
Extracting locale bundle from /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/custom_padded to /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/custom ...
Preparing to install
Checking for POSIX df.
Found POSIX df.
Checking tail options...
Using tail -n 1.
True location of the self extractor: /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/Disk1/InstData/GenericUnix/NoVM/setup.bin
Creating installer data directory: /tmp/install.dir.17841
Creating installer data directory: /tmp/install.dir.17841/InstallerData
Gathering free-space information...
Space needed to complete the self-extraction: 99220 blocks
Available space: 27743952 blocks
Available blocks: 27743952    Needed blocks: 99220 (block = 512 bytes)
This installation does not contain a VM.
Extracting the installation resources from the installer archive...
Extracting install.zip from /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/Disk1/InstData/GenericUnix/NoVM/setup.bin to /tmp/install.dir.17841/InstallerData/installer.zip ...
Extracting to padded done, exit code = 0
Extracting from padded to zip done, exit code = 0
Configuring the installer for this system's environment...
========= Analyzing UNIX Environment =================================
Setting UNIX (linux) flavor specifics.
Importing UNIX environment into LAX properties.
Checking for POSIX awk.
========= Analyzing LAX ==============================================
LAX found............................ OK.
LAX properties read.................. OK.
========= Finding VM =================================================
Valid VM types.......................... J2
Expanded Valid VM types.................  JRE_J2 JDK_J2
JVM specified using LAX_VM
* Using VM:.........(LAX_VM)............ /opt/ptc/app_13.0/Java/bin/java
Inspected VM version -> 17.0.11
Using VM version -> 17.0.11
Java 9 or higher version detected. Adding module access switch.
========= Virtual Machine Options ====================================
LAX properties incorporated............. OK.
classpath............................... "/tmp/install.dir.17841/InstallerData:/tmp/install.dir.17841/InstallerData/installer.zip"
main class.............................. "com.zerog.ia.installer.Main"
.lax file path.......................... "/tmp/install.dir.17841/temp.lax"
user directory.......................... "/tmp/install.dir.17841"
stdout to............................... "console"
sterr to................................ "console"
install directory....................... ""
JIT..................................... none
option (verify)......................... off
option (verbosity)...................... none
option (garbage collection extent)...... none
option (garbage collection thread)...... none
option (native stack max size).......... none
option (java stack max size)............ none
option (java heap max size)............. 500000000
option (java heap initial size)......... 16777216
option (lax.nl.java.option.additional).. none
option (Java 9 and above switch)........ --add-opens java.base/jdk.internal.loader=ALL-UNNAMED -Dsun.java2d.uiScale.enabled=false
========= Display settings ===========================================
X display............................... remote
WARNING:  The name  of  this  host (scllda0436) and  the setting
of this  shell's DISPLAY (:1) variable do not match.
If this launcher is being displayed to a Microsoft Windows desktop
through X Windows the Java Virtual Machine might abort. Try running
this installer locally on the target system or through X Windows to
another UNIX host if the installer unexpectedly fails.
UI mode................................. gui
Launching installer...
========= VM Command Line ============================================
options: --add-opens java.base/jdk.internal.loader=ALL-UNNAMED -Dsun.java2d.uiScale.enabled=false    -Xmx500000000 -Xms16777216
CLASSPATH:/tmp/install.dir.17841/InstallerData:/tmp/install.dir.17841/InstallerData/installer.zip:
========= Forking JAVA =============================================
Picked up _JAVA_OPTIONS: -Djava.io.tmpdir=/tmp
LAX Version = 23.0
__________________________________________________________________________
InstallAnywhere 2023
Version: 23.0
Fri Jun 27 01:44:30 PDT 2025
Free Memory: 9650 kB
Total Memory: 18432 kB
No Arguments
java.class.path:
ZGUtil.CLASS_PATH:
sun.boot.class.path:
    <none specified>
java.ext.dirs:
    <none specified>
java.version                  == 17.0.11 (Java 1)
java.vm.name                  == OpenJDK 64-Bit Server VM
java.vm.vendor                == Amazon.com Inc.
java.vm.version               == 17.0.11+9-LTS
java.vm.specification.name    == Java Virtual Machine Specification
java.vm.specification.vendor  == Oracle Corporation
java.vm.specification.version == 17
java.specification.name       == Java Platform API Specification
java.specification.vendor     == Oracle Corporation
java.specification.version    == 17
java.vendor                   == Amazon.com Inc.
java.vendor.url               == https://aws.amazon.com/corretto/
java.class.version            == 61.0
java.library.path             == /usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib
java.compiler                 == null
java.home                     == /opt/ptc/app_13.0/Java
java.io.tmpdir                == /tmp
os.name                       == Linux
os.arch                       == amd64
os.version                    == 5.14.0-284.69.1.el9_2.x86_64
path.separator                == :
file.separator                == /
file.encoding                 == UTF-8
user.name                     == wcadmin
user.home                     == /home/wcadmin
user.dir                      == /tmp/install.dir.17841
user.language                 == en
user.region                   == null
Loading externalized properties
RepositoryManager: Trying fallback repository location...
System's temporary directory = /tmp
6/27/25, 1:44:37 AM:   === Log Initialized ===
6/27/25, 1:44:37 AM: Created by PTC's Install Framework
6/27/25, 1:44:37 AM:                 host: scllda0436
6/27/25, 1:44:37 AM:              os.name: Linux
6/27/25, 1:44:37 AM:           os.version: 5.14.0-284.69.1.el9_2.x86_64
6/27/25, 1:44:37 AM:              os.arch: amd64
6/27/25, 1:44:37 AM:          java.vendor: Amazon.com Inc.
6/27/25, 1:44:37 AM:         java.version: 17.0.11
6/27/25, 1:44:37 AM:            java.home: /opt/ptc/app_13.0/Java
6/27/25, 1:44:37 AM:      java.class.path: /tmp/install.dir.17841/InstallerData:/tmp/install.dir.17841/InstallerData/installer.zip:
6/27/25, 1:44:37 AM:            user.name: wcadmin
6/27/25, 1:44:37 AM:            user.home: /home/wcadmin
6/27/25, 1:44:37 AM:             user.dir: /tmp/install.dir.17841
6/27/25, 1:44:37 AM:             temp.dir: /tmp
6/27/25, 1:44:37 AM:          working dir: /tmp/install.dir.17841/.
6/27/25, 1:44:37 AM:            time zone: Pacific Daylight Time (PDT)
6/27/25, 1:44:37 AM: Installer log static initialization is complete.
6/27/25, 1:44:37 AM: Setting variable WC.testOutput.extractionDir=/tmp/install.dir.17841.
6/27/25, 1:44:37 AM: Setting variable WC.ifw.temp.installerDataDir=/tmp/install.dir.17841/InstallerData.
6/27/25, 1:44:37 AM: Setting variable WC.ifw.temp.docsDir=/tmp/install.dir.17841/Docs.
6/27/25, 1:44:38 AM:        Env CLASSPATH:
6/27/25, 1:44:38 AM:             Env PATH: /usr/xpg4/bin:/home/wcadmin/.local/bin:/home/wcadmin/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin
6/27/25, 1:44:38 AM: INSTALLER_LAUNCH_DIR: /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/Disk1/InstData/GenericUnix/NoVM
6/27/25, 1:44:38 AM:         INSTALLER_UI: SWING
6/27/25, 1:44:38 AM: CHOSEN_INSTALL_SET: Express
6/27/25, 1:44:38 AM: INSTALLER_LOCALE: en
6/27/25, 1:44:38 AM: CHOSEN_INSTALL_FEATURE_LIST: Application
6/27/25, 1:44:38 AM: CHOSEN_INSTALL_BUNDLE_LIST: Application
6/27/25, 1:44:38 AM:      JAVA_EXECUTABLE: /opt/ptc/app_13.0/Java/bin/java
6/27/25, 1:44:38 AM:   canonical java exe: /opt/ptc/app_13.0/Java/bin/java
6/27/25, 1:44:38 AM: Setting variable $WC.ifw.fullProductName$=PTC Solution Installer.
6/27/25, 1:44:38 AM: Log.init:  set $WC.ifw.fullProductName$ to: PTC Solution Installer
6/27/25, 1:44:38 AM: Setting variable $PRODUCT_NAME$=PTCSolnInstaller.
6/27/25, 1:44:38 AM: Log.init:  set $PRODUCT_NAME$ to: PTCSolnInstaller
6/27/25, 1:44:38 AM: checkStreams: product_log_file_name = PTCSOLNINSTALLER_PtcInstall.log
6/27/25, 1:44:38 AM: checkStreams: ia_product_log_file_name = PTCSOLNINSTALLER_InstallLog.xml
java.lang.ExceptionInInitializerError
at com.ptc.windchill.install.framework.AbstractVariableAccess.getTempDir(AbstractVariableAccess.java:155)
at com.ptc.windchill.install.framework.Log.checkStreams(Log.java:311)
at com.ptc.windchill.install.framework.Log.init(Log.java:257)
at com.ptc.windchill.install.framework.InstallRule.evaluateRule(InstallRule.java:272)
at com.zerog.ia.installer.rules.CustomRule.checkSelf(Unknown Source)
at com.zerog.ia.installer.rules.operators.ANDOperator.evaluateOperator(Unknown Source)
at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluatePostFix(Unknown Source)
at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluateRulesExpressionForPieceAlone(Unknown Source)
at com.zerog.ia.installer.InstallPiece.checkRulesSelf(Unknown Source)
at com.zerog.ia.installer.InstallPiece.checkRules(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.a_(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.a0(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
Caused by: java.lang.NullPointerException: Cannot invoke "String.equals(Object)" because the return value of "com.ptc.windchill.install.framework.PlatformType.getVersion()" is null
at com.ptc.windchill.install.framework.Platform.constInit(Platform.java:116)
at com.ptc.windchill.install.framework.Platform.<clinit>(Platform.java:67)
... 20 more
6/27/25, 1:44:38 AM: java.lang.ExceptionInInitializerError
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.AbstractVariableAccess.getTempDir(AbstractVariableAccess.java:155)
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.Log.checkStreams(Log.java:311)
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.Log.init(Log.java:257)
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.InstallRule.evaluateRule(InstallRule.java:272)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.rules.CustomRule.checkSelf(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.rules.operators.ANDOperator.evaluateOperator(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluatePostFix(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluateRulesExpressionForPieceAlone(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.InstallPiece.checkRulesSelf(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.InstallPiece.checkRules(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.LifeCycleManager.a_(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.LifeCycleManager.a0(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.Main.main(Unknown Source)
6/27/25, 1:44:38 AM: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
6/27/25, 1:44:38 AM: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
6/27/25, 1:44:38 AM: at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
6/27/25, 1:44:38 AM: at java.base/java.lang.reflect.Method.invoke(Method.java:568)
6/27/25, 1:44:38 AM: at com.zerog.lax.LAX.launch(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.lax.LAX.main(Unknown Source)
6/27/25, 1:44:38 AM: Caused by: java.lang.NullPointerException: Cannot invoke "String.equals(Object)" because the return value of "com.ptc.windchill.install.framework.PlatformType.getVersion()" is null
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.Platform.constInit(Platform.java:116)
6/27/25, 1:44:38 AM: at com.ptc.windchill.install.framework.Platform.<clinit>(Platform.java:67)
6/27/25, 1:44:38 AM: ... 20 more
6/27/25, 1:44:38 AM: The installation is aborting due to an unexpected error.
6/27/25, 1:44:38 AM: Exiting with return code -1
6/27/25, 1:44:38 AM: ----- End: com.ptc.windchill.install.rules.IsValidJavaVersionRule @ 37427881 -----
null
    class com.ptc.windchill.install.rules.IsValidJavaVersionRule.install() runtime exception:
java.lang.NullPointerException: Cannot invoke "java.io.File.getAbsolutePath()" because "<parameter5>[<local7>]" is null
at com.ptc.windchill.install.framework.GUIAborter.renderMessage(GUIAborter.java:56)
at com.ptc.windchill.install.framework.AbstractAborter.abortInstallation(AbstractAborter.java:75)
at com.ptc.windchill.install.framework.InstallRule.abortInstallation(InstallRule.java:349)
at com.ptc.windchill.install.framework.InstallRule.evaluateRule(InstallRule.java:306)
java.lang.NoClassDefFoundError: Could not initialize class com.ptc.windchill.install.framework.Platform
Caused by: java.lang.ExceptionInInitializerError: Exception java.lang.NullPointerException [in thread "main"]
... 20 more
6/27/25, 1:44:38 AM: java.lang.NoClassDefFoundError: Could not initialize class com.ptc.windchill.install.framework.Platform
6/27/25, 1:44:38 AM: Caused by: java.lang.ExceptionInInitializerError: Exception java.lang.NullPointerException [in thread "main"]
6/27/25, 1:44:38 AM: ----- End: com.ptc.windchill.install.rules.IsSupportedInstallConfigurationRule @ 454547627 -----
null
    class com.ptc.windchill.install.rules.IsSupportedInstallConfigurationRule.install() runtime exception:
java.lang.IllegalStateException: PsiAccess is not initialized.
at com.ptc.windchill.install.suite.PsiAccess.getInstance(PsiAccess.java:48)
at com.ptc.windchill.install.suite.LegacyController.getVariableAccess(LegacyController.java:726)
at com.ptc.windchill.install.suite.LegacyController.isSilentInstall(LegacyController.java:112)
at com.ptc.windchill.install.suite.LegacyController.is4kResolution(LegacyController.java:117)
at com.ptc.windchill.install.psi.ui.swing.SwingOptions.getDefaultFont(SwingOptions.java:59)
at com.ptc.windchill.install.psi.ui.swing.ComponentFactory.configureComponent(ComponentFactory.java:83)
at com.ptc.windchill.install.psi.ui.swing.ComponentFactory.makeJPanel(ComponentFactory.java:119)
at com.ptc.windchill.install.psi.ui.swing.ComponentFactory.makeJPanel(ComponentFactory.java:114)
at com.ptc.windchill.install.psi.ui.swing.panels.CustomPostInstallSummaryPanelImpl.initComponents(CustomPostInstallSummaryPanelImpl.java:145)
at com.ptc.windchill.install.psi.ui.swing.panels.PanelImplBase.<init>(PanelImplBase.java:57)
at com.ptc.windchill.install.psi.ui.swing.panels.PanelImplBase.<init>(PanelImplBase.java:39)
at com.ptc.windchill.install.psi.ui.swing.panels.CustomPostInstallSummaryPanelImpl.<init>(CustomPostInstallSummaryPanelImpl.java:81)
at com.ptc.windchill.install.psi.ui.swing.panels.CustomPostInstallSummaryPanel.<init>(CustomPostInstallSummaryPanel.java:31)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)
at java.base/java.lang.reflect.ReflectAccess.newInstance(ReflectAccess.java:128)
at java.base/jdk.internal.reflect.ReflectionFactory.newInstance(ReflectionFactory.java:347)
at java.base/java.lang.Class.newInstance(Class.java:645)
at com.zerog.ia.installer.actions.InstallPanelAction.getInstallPanel(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.an(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.preflightInstallerResources(Unknown Source)
at com.zerog.ia.installer.Installer.checkInstallerRules(Unknown Source)
at com.zerog.ia.installer.AAMgr.startPreInstall(Unknown Source)
at com.zerog.ia.installer.AAMgrBase.runPreInstall(Unknown Source)
at com.zerog.ia.installer.AAMgr.runPreInstall(Unknown Source)
at com.zerog.ia.installer.LifeCycleManager.b_(Unknown Source)
... 9 more
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.Installer.checkInstallerRules(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.AAMgr.startPreInstall(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.AAMgrBase.runPreInstall(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.AAMgr.runPreInstall(Unknown Source)
6/27/25, 1:44:38 AM: at com.zerog.ia.installer.LifeCycleManager.b_(Unknown Source)
6/27/25, 1:44:38 AM: ... 9 more
null
... 9 more
null
installDebug: start pre-install
installDebug: start com.ptc.windchill.install.suite.PsiAccess
6/27/25, 1:44:39 AM: checkStreams: product_log_file_name = PTCSOLNINSTALLER_PtcInstall.log
6/27/25, 1:44:39 AM: checkStreams: ia_product_log_file_name = PTCSOLNINSTALLER_InstallLog.xml
at com.ptc.windchill.install.framework.InstallAction.install(InstallAction.java:317)
at com.zerog.ia.installer.actions.CustomAction.installSelf(Unknown Source)
at com.zerog.ia.installer.util.GenericInstallPanel$2.run(Unknown Source)
6/27/25, 1:44:39 AM: java.lang.NoClassDefFoundError: Could not initialize class com.ptc.windchill.install.framework.Platform
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.AbstractVariableAccess.getTempDir(AbstractVariableAccess.java:155)
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.Log.checkStreams(Log.java:311)
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.Log.init(Log.java:257)
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.InstallAction.install(InstallAction.java:317)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.actions.CustomAction.installSelf(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.util.GenericInstallPanel$2.run(Unknown Source)
6/27/25, 1:44:39 AM: Caused by: java.lang.ExceptionInInitializerError: Exception java.lang.NullPointerException [in thread "main"]
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.Platform.constInit(Platform.java:116)
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.Platform.<clinit>(Platform.java:67)
6/27/25, 1:44:39 AM: at com.ptc.windchill.install.framework.InstallRule.evaluateRule(InstallRule.java:272)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.rules.CustomRule.checkSelf(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.rules.operators.ANDOperator.evaluateOperator(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluatePostFix(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.rules.operators.RuleEvaluationUtility.evaluateRulesExpressionForPieceAlone(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.InstallPiece.checkRulesSelf(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.InstallPiece.checkRules(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.LifeCycleManager.a_(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.LifeCycleManager.a0(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.LifeCycleManager.executeApplication(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.Main.main(Unknown Source)
6/27/25, 1:44:39 AM: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
6/27/25, 1:44:39 AM: at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
6/27/25, 1:44:39 AM: at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
6/27/25, 1:44:39 AM: at java.base/java.lang.reflect.Method.invoke(Method.java:568)
6/27/25, 1:44:39 AM: at com.zerog.lax.LAX.launch(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.lax.LAX.main(Unknown Source)
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.suite.PsiAccess @ 283219816 -----
Execute Custom Code
    class com.ptc.windchill.install.suite.PsiAccess.install() runtime exception:
java.lang.NullPointerException: Cannot invoke "com.ptc.windchill.install.framework.Aborter.abortInstallation(Object, String, Object[], java.lang.Throwable, int)" because "this.aborter_" is null
at com.ptc.windchill.install.framework.InstallAction.abortInstallation(InstallAction.java:596)
at com.ptc.windchill.install.framework.InstallAction.install(InstallAction.java:355)
installDebug: end com.ptc.windchill.install.suite.PsiAccess
installDebug: start com.ptc.windchill.install.suite.actions.DeveloperInputsValidatorIaAction
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.suite.actions.DeveloperInputsValidatorIaAction @ 485517731 -----
Execute Custom Code
    class com.ptc.windchill.install.suite.actions.DeveloperInputsValidatorIaAction.install() runtime exception:
installDebug: end com.ptc.windchill.install.suite.actions.DeveloperInputsValidatorIaAction
installDebug: start com.ptc.windchill.install.suite.GlobalRegistryCleanupAction
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.suite.GlobalRegistryCleanupAction @ 1540918735 -----
Execute Custom Code
    class com.ptc.windchill.install.suite.GlobalRegistryCleanupAction.install() runtime exception:
installDebug: end com.ptc.windchill.install.suite.GlobalRegistryCleanupAction
at com.zerog.ia.installer.actions.ActionGroup.checkRulesSelf(Unknown Source)
at com.zerog.ia.installer.AAMgrBase.ai(Unknown Source)
at com.zerog.ia.installer.AAMgr.ac(Unknown Source)
at com.zerog.ia.installer.AAMgrBase.aj(Unknown Source)
at com.zerog.ia.installer.AAMgrBase.runNextInstallPiece(Unknown Source)
at com.zerog.ia.installer.AAMgr.actionPerformed(Unknown Source)
at java.desktop/java.awt.Button.processActionEvent(Button.java:419)
at java.desktop/java.awt.Button.processEvent(Button.java:387)
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5001)
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4833)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:775)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:399)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:97)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:747)
at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:744)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.actions.ActionGroup.checkRulesSelf(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgrBase.ai(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgr.ac(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgrBase.aj(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgrBase.runNextInstallPiece(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgr.actionPerformed(Unknown Source)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.Button.processActionEvent(Button.java:419)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.Button.processEvent(Button.java:387)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5001)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.Component.dispatchEvent(Component.java:4833)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:775)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:720)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:714)
6/27/25, 1:44:39 AM: at java.base/java.security.AccessController.doPrivileged(AccessController.java:399)
6/27/25, 1:44:39 AM: at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
6/27/25, 1:44:39 AM: at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:97)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:747)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:744)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
6/27/25, 1:44:39 AM: at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
6/27/25, 1:44:39 AM: The installation is aborting due to an unexpected error.
6/27/25, 1:44:39 AM: Exiting with return code -1
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.rules.IsSilentInstallRule @ 1852545129 -----
null
    class com.ptc.windchill.install.rules.IsSilentInstallRule.install() runtime exception:
installDebug: start com.ptc.windchill.install.suite.actions.SilentInstallValidationAction
at com.zerog.ia.installer.AAMgrBase.ak(Unknown Source)
at com.zerog.ia.installer.AAMgr.a2(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgrBase.ak(Unknown Source)
6/27/25, 1:44:39 AM: at com.zerog.ia.installer.AAMgr.a2(Unknown Source)
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.suite.actions.SilentInstallValidationAction @ 2011362047 -----
Execute Custom Code
    class com.ptc.windchill.install.suite.actions.SilentInstallValidationAction.install() runtime exception:
installDebug: end com.ptc.windchill.install.suite.actions.SilentInstallValidationAction
6/27/25, 1:44:39 AM: ----- End: com.ptc.windchill.install.rules.IsNotSilentInstallRule @ 979532722 -----
null
    class com.ptc.windchill.install.rules.IsNotSilentInstallRule.install() runtime exception:
installDebug: start Panel custom code com.ptc.windchill.util.install.BeforeYouBeginPanel
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class com.ptc.windchill.install.framework.Platform
at com.ptc.windchill.install.framework.InstallPanel.setupServicesForUI(InstallPanel.java:661)
at com.ptc.windchill.install.framework.InstallPanel.setupUI(InstallPanel.java:641)
at com.zerog.ia.installer.AAMgr.ay(Unknown Source)
Where do you get the log information?
Try to run the installer "setup" from PSI folder /opt/ptc/staging_software/MED-61006-CD-130_13-0-2-5_13-0-2-5-Bundle/ptc_solution_installer_13.0.2.5/ instead of the Bundle folder "setup.sh" , then capture a screenshot of the command "ls -lt" under the tmp folder
Nothing jumped out to my but it seems like it had issues extracting installer to the tmp directory. Make sure there is enough space and you can execute in that folder: https://www.ptc.com/en/support/article/CS408865?source=search
In my case it was too small so I used those settings to have it run from another folder with more space. Also, when posting to this board, be sure to practice good cyber security and not expose personal details like hostnames and usernames publicly.
Already tried the said options but no luck..
Just removed the screenshot.
I've always done install as root then changed settings to be another user. Reason is that installer will install Apache or the PTC HTTPServer and that needs to startup during the install. That means it will try to run port 80 initially and that will need root privileges (right?, less that 1000). After I have a working system, I chown files to my main user, non root. Reading your log extract, sounds like you not even getting that far. Still reading. Post as attachment next time.
Tried launching with Root as well but no luck.
One of the challenging and strange issue, not seen in recent days.
Per the previous stack trace, it seems that the installer can't get the platform version correctly.
Next Step:
Delete the files and sub folders under /tmp, and then try to run the command "setup" with ROOT under PSI folder, then check if the installer will create the /tmp/root and  /tmp/install.dir.#### folders as well as a log file
KV_12355386
6-Contributor
(To:Jimwang)
i did try deleting files from /tmp and relaunching.. Same issue persist.
Do you see any log files generated under /tmp? Please attach /etc/redhat-release file here.
KV_12355386
6-Contributor
(To:Jimwang)
 Pls check the attachment.
It looks like the file is OK. To check the platform version, run the attached java class and provide the output result here.
To test it:
1>Create a temp folder
2>Unzip the attached file to the temp folder
3>Run the below command under the folder: java -cp . PlatformTypetest
KV_12355386
6-Contributor
(To:Jimwang)
[ PlatformTypeTest]$ java -cp . PlatformTypetest
Error: Could not find or load main class PlatformTypetest
Caused by: java.lang.ClassNotFoundException: PlatformTypetest
Hmm, sorry, there is a typo in my command, it should be : java -cp . PlatformTypeTest
KV_12355386
6-Contributor
(To:Jimwang)
Run the tool at: 2025-07-03T01:53:08.580116525
Java version: 17.0.11
Operating System: Linux
**** GetType: Linux
**** OS Type: UNIX
**** currentOS Name: Linux
**** PT getVersion: null
Exception in thread "main" java.lang.NullPointerException: Cannot invoke "String.equals(Object)" because the return value of "PlatformTypeTest.getVersion()" is null
at PlatformTypeTest.main(PlatformTypeTest.java:192)
I updated the utility by adding more debug information, please download the new attachment and test it with the below steps:
3>Run the below command under the folder: java -cp . PlatformTypeTest
After that, please put the output of the result  here.
KV_12355386
6-Contributor
(To:Jimwang)
========= ***** PlatformTypeTest is initializing ..... *****========= !
------ getSysProp is null for the retStr: os.temp
------ getSysProp is null for the retStr: sun.cpu.isalist
---------- After Initilized, PT osVersion is: 5.14.0-284.69.1.el9_2.x86_64
>>>>>> Begin determineOsVersion, getVersion result is: 5.14.0-284.69.1.el9_2.x86_64
<< /etc/issue file osVersion is: null
<<<<<< After determineOsVersion, the osVersion is: null
Run the tool at: 2025-07-03T11:12:07.662559151
Operating System Name: Linux
Operating System Version: 5.14.0-284.69.1.el9_2.x86_64
**** PT initialized currentOS Name: Linux
**** PT initialized osVersion: null
at PlatformTypeTest.main(PlatformTypeTest.java:194)
Next Steps:
KV_12355386
6-Contributor
(To:Jimwang)
$ java -cp . PlatformTypeTest
==>> setLinuxOSVersion of line is: Red Hat Enterprise Linux release 9.2 (Plow)
===>> setLinuxOSVersion of REDHAT9 line.matches('(?i).*release 9.*') is: REDHAT9
<< /etc/redhat-release osVersion is: REDHAT9
==>> setLinuxOSVersion of line is: NAME="Red Hat Enterprise Linux"
===>> setLinuxOSVersion of REDHAT9 releaseInfo((?i).*release 9.*) is: REDHAT9
<< /etc/os-release is: REDHAT9
<<<<<< After determineOsVersion, the osVersion is: REDHAT9
Run the tool at: 2025-07-03T20:01:12.495648473
**** PT initialized osVersion: REDHAT9
===== PlatformTypeTest initialized with the following variables:
CurrentOS: Linux
OS Version: REDHAT9
OS Architecture: amd64
Processor Identifier:
Processor Architecture:
getOS Name: LINUX
OS getVersion: REDHAT9
ARCH: UNKNOWN
TYPE: UNIX
i'm able to see the Next button now. Thanks a lot.. Thanks is just a simple word.. you had resolved the issue which i had been following up with PTC from last one month..
Appreciate you help. Thanks once again.
That is great.
KV_12355386
6-Contributor
(To:Jimwang)
Any idea, why issue occured in first place.
Any possible reason, i did in different host there as well i had same issue.
PSI will check the system environment configuration firstly, and your systems may have the same configuration created by your IT, that could be the reason the same issue happened in different hosts.
