Difficulties to change settings in wt.properties.xconf
SOLVED
Gravel
Hi there,
our users required to enable the search for empty attribute fields. The Windchill documentation states that this can be done by setting the property com.ptc.windchill.search.queryBuilder.enableNullCriteria in wt.properties.xconf to true.
I am used to edit settings with the xconfmanager tool. The command
xconfmanager -s com.ptc.windchill.search.queryBuilder.enableNullCriteria=true -t codebase\wt.properties.xconf -p
failed with a lengthy error message (see attached file).
In the wt.properties.xconf file, a comment has been inserted at the beginning:
#-*- XCONF CONTENT START -*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-
# WARNING:
#    This file has been updated by the xconfmanager tool located in,
#    $(wt.home)\bin but this file is not declared by PTC as being managed
#    via xconf.
#    To ensure that your settings will be preserved the next time the
#    xconfmanager is run or an installer is used to install a new product or
#    a maintenance update to the currently installed products:
#     ****    DO NOT MODIFY THE CONTENTS OF THIS FILE DIRECTLY!    ****
#    If you are configuring this installation and you wish to change a value
#    from its default,  edit your site-specific xconf configuration file:
#       C:\ptc\Windchill_11.0\Windchill\site.xconf
#    using the xconfmanager tool located in $(wt.home)\bin.  You may run the
#    command 'xconfmanager -h' to obtain a usage statement for this tool.
#    The following properties are specified in xconfs:
#      - com.ptc.windchill.search.queryBuilder.enableNullCriteria
#-*- XCONF CONTENT END -!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-
So my question is: How do I properly set options in wt.properties.xconf? And how can I revert the changes?
Thank you in advance for your comments.
Best
Chris
1 ACCEPTED SOLUTION
Re: Difficulties to change settings in wt.properties.xconf
Target file is incorrect in your command
xconfmanager -s com.ptc.windchill.search.queryBuilder.enableNullCriteria=true -t codebase\wt.properties -p
 To revert to default you need need to remove entry from site.xconf and propagate with following command:
xconfmanager -p
xconfmanager -p
Problem solved! Thanks a lot for your help, Vincent-Kulak!
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________ Check out the Windchill Tips Board! We're talking about Whirlpool's use of digital twin, augmented reality, and data-driven design!
The NAVIGATE WORKING GROUP is here! Come innovate with PTC!
Sign up for a Working Group
