Is there a way to disable the authentication for a single endpoint (custom JSP).
oups sorry, the article is internal.
Here is the solution :
2. Restart Apache
Hi Alex, hope you are fine.
Did you checked this article https://www.ptc.com/en/support/article?n=CS273315 available in our kownledge base ?
Hicham
2. Restart Apache
Hi
Be carful here, if you do this your jsp will not have access to method server or databases....
Regards
