We are happy to announce the new Windchill Customization board! Learn more.
Display Change Tasks
lgrant
How do we display Change Task in a Folder View? The Default "Change Objects" does not display Task.
I do not see an option to include Change Task in a customized View.
V11 M020
Cheers.
9 REPLIES 9
STEVEG
(To:lgrant)
Make sure that type is set to show in the view.  It might not be shown as a default.
JeffZemsky
(To:lgrant)
Change Tasks are not Foldered objects and can't be see in Folders - you can find them within their Change Notices and if you enable it you can search on them as well.  Also you could create reports as well as see them in Task lists
STEVEG
(To:JeffZemsky)
You are correct Jeff.  My mistake.
It has been nice that we can search for Tasks after we enabled it.
JeffZemsky
(To:STEVEG)
No worries Steve.
lgrant
(To:JeffZemsky)
I created a quick report to search for them but it sure would be nice to see and navigate to them. The report did not have (that I could find) the option to view the details (information) page on the object.
STEVEG
(To:lgrant)
Go to the Select tab and hit the Add button.
Assuming 10.1 is somewhat the same as 11...
Select the browse icon (with the 3 dots)
Change to the correct type and select the first one
This should give you the information icon to go to the detail page.
JeffZemsky
(To:lgrant)
You can display the (i) hyperlink you use the technique in Help - Show information page link in results table
Here is an example:
This results in the following:
STEVEG
(To:JeffZemsky)
Dang.  I am definitely looking forward to 11.
JeffZemsky
(To:STEVEG)
Steve - Queryl Builder and Report Builder have some nice touches to make reports slicker.  Particularly better management of the criteria for Report Builder to streamline what users can and can't pick.  Query Builder is a lot easier to deal with too as it gives you the relationships from an object making it easier to create reports without being a full on expert in the data model.  Still not fully for dummies - it makes it easier then to create Report Builder Reports that users can then tailor to their needs.
