When trying to import a reqif file into my DOORS system Windchill reports this error:
Document 'xxx' uses 3 object types, only one is supported.
Any recommendation how to fix that by using refactoring?
Hi @FB_7077746
It is good to know that knowledge base contains this information
CS280996 - How to import document with multiple object types in Integrity Requirements Connector
PetrH
Hi @FB_7077746,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Best regards,
Hi @FB_7077746
PetrH
