I am trying to figure out if conditional watermarking is possible: (we want the watermark to = value of PART_CLASSIFICATION for all cases except when that value is UNCLASSIFIED, then we want it to be something like SECRET/RD PENDING REVIEW). The actual label doesn't matter. The main question is: Is it possible to have the watermark feature support logic in terms of which watermark it uses?
Thanks for any help.
WVS Adobe Experience Manager Server Integration
Which file formats should have the watermark? Is it on a drawing PDF or on Creo view viewables?
If it is PDF out of the box solution is to go by Adobe Experience Manager for which you have to buy a server license from PTC. If you are willing to develop a customization, it is fairly easy using opensource PDFs. I have something which I can share with you
Ideally it should be both PDFs and CreoViewables. Anything you have that is related would be great to look at. Thanks
