Does PDMLink/Windchill support TLS 1.2?
Which version/CPS are you in ? TLS 1.2 is supported from Apache version 2.2.23+. So if you in one of the latest version, you are good to use TLS 1.2. If you are using Arbortext client, there are some limitations around TLS 1.2
