Hello everyone:
Thanks to 64 bit os have better performance,I want to install Windchill PDMLink on Windows 2003 64 bit OS.I want to know if windchill's softwares support the 64 bit os?
Best regads.
What Windchill version are you going to install?
In any case, check the Software Matrices in Reference Documents section on ptc.com
First of all,thank you for you response.
The version of our windchill is 8.0 M050.As i see in the Windchill80M050SoftwareMatrix,java server site doesn't support 64-bit editions of Windows 2003 Server.
"Applies to all 32-bit editions of Windows 2003 Server. 64-bit versions of the operating system are not supported at this time."
So ,maybe install on 64-bit editions of Windows 2003 Server is not feasible.
I don't think 8.0 support 64bit os.
It won't work on 2008
I might work on 2003 - 64 bit. Just try to launch the Tomcat Installer for example. the Installanywhere package has an hard coded set of OS releases and there is no way as far as I know (tried many times to bypass it)to work around this.
There are some tools otherwise that can simulate a different sub release information tempary so you could try this as well
