Hello all,
I'm currently trying to downgrade a windchill 9.1 M060 to M010 instance on Ubuntu.
I did not want to keep database data.
To do this, i just move the older /opt/ptc/Windchill to another one.
After, i start PSI as root and fill content. PSI install successfully java, tomcat, apache and Aphelion and stop with message "ocu installer failed to start".
If i change my PSI setup without OCU, at the same step as OCU did, PSI stops with message "ie installer failed to start".
Here are messages on /opt/ptc/Windchill/installer/logs/PTCSOLNINSTALLER_PtcInstall.log (Notice that nullpointer appears after validating error message) :
12/12/11 16:05:08: Running: su vmuser -c /mnt/hgfs/C/tmp2/MED-60419-CD-091_M010_third/OCU/setup LAX_VM /var/tmp/ptc_installer_jres/Sun_JRE_1.6.0_10_Linux_INTEL/jre/bin/java -f /opt/ptc/Windchill_9.1/installer/PSITempProps/ocu-installer.properties -DMULTI_PROGRAM_EXEC=1
Starting: /mnt/hgfs/C/tmp2/MED-60419-CD-091_M010_third/OCU/Disk1/InstData/GenericUnix/NoVM/setup.bin LAX_VM /var/tmp/ptc_installer_jres/Sun_JRE_1.6.0_10_Linux_INTEL/jre/bin/java -f /opt/ptc/Windchill_9.1/installer/PSITempProps/ocu-installer.properties -DMULTI_PROGRAM_EXEC=1
Please wait...
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Preparing SILENT Mode Installation...
Oracle Configuration Utility (created with InstallAnywhere by Macrovision)
12/12/11 16:05:27: Installation is Aborting. The installation cannot continue.
12/12/11 16:35:55: Aborting installation.
12/12/11 16:35:55:
12/12/11 16:35:55:
12/12/11 16:35:55: -- Reason --
12/12/11 16:35:55: Installation is Aborting. The installation cannot continue.
12/12/11 16:35:55:
12/12/11 16:35:55:
12/12/11 16:35:55: -- Details --
12/12/11 16:35:55: ocu installer failed to start.
SHUTDOWN REQUESTED
(X) commiting registry
RepositoryManager: repository successfully written to stable storage
(X) shutting down service manager
(X) cleaning up temporary directories
java.lang.NullPointerException
cleanUp()
calling cleanUpUNIX()
Exiting with exit code: 255
Thanks for your help
Are you deleting this directory?
It sounds like you are basically doing a reinstall in addition to dropping the database user or all db content?
First step, i moved the old /opt/ptc/Windchill9.1 folder to another one.
Next, at each try, i delete the /opt/ptc/Windchill9.1 folder that PSI have created.
I've keep all data on the db.
