Drawing and Model Revision - Matched or Don't Care???
Windchillers, I am wondering how companies are handling drawing and model revision numbers/letters... MATCHED REVISIONSDo you require that the drawing and model have the same revision? In the example below, both the part and the drawing are at Revision A. The logic here is that it is easy for someone to look at the drawing and realize they need rev A of the model. It makes sense, but might be more work in some cases to keep this synch'd up. 12345.drw A.1, Released12345.prtA.6, Released DON'T CAREOr, do you allow the drawing and the model to have different revisions? The logic here is that it is theDrawing Revisionthat shows up in the Title Block,not the part revision so why worry about it.Also, PDMLink knows which version of the part goes with A.1 of the drawing, sothe usersdont need to be bothered with keeping them synch'd. 12345.drw A.1, Released12345.prt1.2, Released Any feedback is appreciated! Andy B.
