Drop Down on the Task Page of an Activity
ptc-5091742
Hi ,
I have a requirement:-
In a workflow for a particular activity , when a user recieves the task , user should see two attributes 1. Company 2. Country in the task page.
Also the input for the attributes should ONLY be a drop down list.
In the Workflow template , i have created two variables in the activity of type name : wt.org.WTUser to achieve the drop down but this only gives the names of users in the Windchill system in the drop down list.
Please suggest. Please refer the screenshot attached.
Ishaan
Hello Lori ,
I have created a custom class . Now when i try to put the name of my custom class after other class option , it gives a error which says : Only evolvable or persistable classes can be made as a type of variable in a workflow.
Does that mean i have to make the values persistable using persistence helper in my class?
or anything else?
Ishaan Nayyar
10 REPLIES 10
LoriSood
(To:ptc-5091742)
The wt.org.WTUser type will only display user information in the pull-down list. From what I've been able to determine the CustomVariablesDataUtility.java is the data utility class used to render workflow variables on a task's page. The class checks for the variable type and if it is Enumerated type (i.e. extends the EnumeratedType class) then it renders the variable as a drop-down list. You will probably need to create a custom class that will extend EnumeratedType and specify the class as the task variable.
KD
(To:LoriSood)
Hi Lori Lee Sood,
About your solution I have one question.
How will I specify my own extended Class as workflow variable ??
Cause I can only specify some predefined windchill class and only those classes which implements Persistable and Evolable as workflow variable.
Thanks and Regards,
Kaushik
LoriSood
(To:KD)
Hi Kaushik,
In my Type Name drop-down list I have the option to select Other Class... and then I can specify a different class other than those listed. Do you not have this same option?
Hello Lori ,
or anything else?
Ishaan Nayyar
KD
(To:ptc-5091742)
See this thread "http://communities.ptc.com/message/190099#190099".
1. Update the wt.properties and set the property
wt.workflow.definer.variable.ShowWfEvolvableWarning=true,
  • So that the non persistable and non evolvable classes can be used to define workflow variables.
    The user will receive a warning message but he can save or update non-persistable and non evolvable objects into variables.
This can be done by making changes in site.xconf and automatically the property is propagated in wt.properties
-------changes in site.xconf---------------
<Property name="wt.workflow.definer.variable.ShowWfEvolvableWarning" overridable="true"
targetFile="codebase/wt.properties"
value="true"/>
Now go to windchill shell and run a command -->xconfmanager -p
Thanks And Regards,
Kaushik
ptc-5091742
(To:KD)
Genious Kau Das
I did this already by the way. The class is now persistable , it gives a error message though but later Windchill accepts.
Ishaan Nayyar
LoriSood
(To:KD)
Great, Kaushik! I have to admit that I have not yet been trained on all the ins and outs of Windchill customization (that's coming very soon) so it was taking me some time to figure out which step was missing. I'm glad you got it figured out.
KD
(To:LoriSood)
Thank you Lori,
Hope after your customization training we will get more and more answer from you.
Thanks And Regards ,
Kaushik
sahmed-5
(To:KD)
I am looking for similar solution but the values in the drop down list should be multi select. can you please help me with any idea.
Thanks in advance.
albertrj
(To:sahmed-5)
Wanted to know if you were able to acheive this. If yes can you please provide some details?
Thanks in advance,
Albert
