Dumb Question?
drichards
2-Explorer
Dumb Question?
Is it possible to add parameters, or change parameter values from within Windchill PDMLink? If out ot the box the answer is no, is it possible with custom development?
Of course yes OOTB! You can add attributes using the TypeManager.
In Reply to Dan Richards:
From what I have done with PDMLink, I would guess you can probably do it on multiple files such as files within search results? Does it involve reving up the file or files? And can it be done on all files which don't already have the parameter?
Not sure to understand you....
You add attributes on object type (expanding its data model). Then every objects of that type will have those new attributes (obviusly blanck or null).
