Dynamic Routing Option
hbock
Is there a possibility to set the list of routing options of a task depending on a variable when starting a task?
I only found the "tally" method to set up events automatically but that does not seem to help in my use-case.
Use-Case:
Skip a routing option when a process/task variable has a specific value.
Pre-Condition / dependend variable:
                boolean ir_autocreated;
Routing in Task:
A
B
C
X
For Routing „X“ there shall be valid:
IF ir_autocreated == true THEN Routing Option “X” shall be "invisible" / not selectable in the task
Thank You in advance
Harald
HelesicPetr
(To:hbock)
Hi @hbock
So do you need to specify routings on some rules in a user task right?
So create a condition in a Workflow that controls what you need and define routs for several users tasks with different routings as you need.
Then just run the task with correct routings that are shown to a user
PetrH
6 REPLIES 6
pranaam
(To:hbock)
Hello Hbock,
Did you manage to implement the routing options that you have described ? I am looking at a similar scenario and wanted to know how to disable or hide a routing based on some logic.
Much appreciate your response if you succeeded in implementing the same.
Regards.
hbock
(To:pranaam)
No, no success so far.
I was contacted by a PTC person form technical support, but also on this channel no news
Best Regards
Harald
Hi!
Any news about that topic?
Best regards,
Mike
... unfortunately not 😞
Maybe someone of the PTC team reading along could make a statement about this feature.
HelesicPetr
(To:hbock)
Hi @hbock
PetrH
Yes, sure, this is the currently possible workflow implementation. Thank you for pointing this out.
I will mark this as "solution", as there most probably will be no change in the system in the future...
