Hi @LF_10793352
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
That was a little hard to follow. Could you clarify a bit?
It sounds like you're using ECNs in Windchill. I'm not sure what you mean by "affected products." To my knowledge, ECNs capture the Affected and Resulting "Objects". For both of these, it's something a user has to select.
I'm not sure where "affected system" is coming from? Do you have any customizations running on your ECNs?
I'm also having trouble understanding the your last sentence. What is the desired function, and what is happening instead?
