EDIT OIR XML
cspinelli
EDIT OIR XML
hello,
is it possible to edit XML file associated to OIR instead of deleting?
thanks
Fadel
23-Emerald I
(To:cspinelli)
Make sure you have permission , use wcadmin user, to be on safe side
Fede
HelesicPetr
(To:cspinelli)
Hi @cspinelli
What do you mean XML associated to OIR?
OIR is the XML file that describes the rules.
You can download it and modify the file in a text editor and then upload it by OIR edit function.
So you don't have to delete the rule and add new one.
You can just edit it.
PetrH
cspinelli
(To:HelesicPetr)
ok thanks so maybe i've not the Edit function in Windchill 10,2
Fadel
23-Emerald I
(To:cspinelli)
Fede
