Hi All,
I am opting for the checkout/checking instead of merge/rollbackup
I am having some troubles with the following:
CheckoutLink myCheckOutLink = wt.vc.wip.WorkInProgressHelper.service.checkout(myworkable,
wt.vc.wip.WorkInProgressHelper.service.getCheckoutFolder(),"Batch",true);
It seems that the boolean parameter "allowNonLatestCheckout" set to true is not working:
error 7(wt.vc.wip.wipResource/31) wt.vc.wip.NonLatestCheckoutException:
CAD Part - test.prt, A.1 can not be checked out because it is not the latest iteration.
Anyone used the 9.0 M030/M060 code has the checkout of non latest iteration should be working?
Other suggestions?
