Version: Windchill 12.1
Use Case: Mailer fails to send email about queue over threshold
Description:
I am able to send emails just fine using "email page", but I am getting an error when the Windchill tries to email system status updates to the same address. This is something I just noticed has never worked since our 12.1 upgrade from 11 (new server, new company policies) so I'm not sure where the issue actually is.
Any ideas why it's failing?
Article - "How to avoid error message "wt.jmx.core.mbeans.Emailer - Attempt to send mail failed [Id=1; Subject='xxx']" when start Windchill Server in Windchill PDMLink": https://www.ptc.com/en/support/article/CS328847
Hi @Aaronm87,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
