I would open a ticket with tech support. You might get the answer that is working to spec. If you do want this supported, I would submit an idea and indicate how you would want the ERP system to handle phantom CAD.
Hi, Please let me know. Need support
When i check the BOM structure there is no Phantom CAD sub assembly that i can see.
