Version: Windchill 12.1
Use Case: Taking hours of time to get ESI response file Generation
Description:
After we upgraded Windchill 11.1 to 12.1 and also to database update to 19c,we are seeing significant increase in ESI response file generation. In Windchill 11.1,BOM with 500 parts with Options and assigned expressions used to take less than one minute and now it is taking more than 8 minutes. In most of business cases, we release more than 5 BOMs in sign ECN and that is taking 40 minutes to generate ESI Response file. Checked with PTC,they are saying that is expected behavior but it is not the case in Windchill 11.1. Posting the message here to check If anyone experienced similar issue.
Any insights or suggestions would be greatly appreciated.
There is bug in PTC Code,they are fixing it now.Below article and SPR raised for this
Article - CS449461 - Windchill ESI Response xml is taking lot of time to generate when the new unchanged Release Activity is created for the same choice
Hi Fade,
Thank you very much for your response.
Thank you
Srinivas
Hi , if tuning database doesn't help you may raise a support case to have a performance Engineering Review the settings and properties .
