Version: Windchill 13.0
Use Case: How to configure eclipse in a local machine where windchill is not installed? All the jars from WEB-INF/Lib and Codebase/LIB are copied but still the import commands throw error. Has something changed in windchill 13 with import of Jars?
Description:
You have to configure your IDE to use je libraries in the project,
Something like this >
PS> you have not mentioned any error you could see.
PetrH
Hi @AP_10483126
Nothing has been changed in general.
I keep using the machine without Windchill installation and IDE works without any trouble.
I use library for all windchill versions based on a project. 10.2, 11.0. 11.1, 12.0, 12.1 , 13,0 , 13,1
as a last library I used windchill 13.1.2.0
You should be more specific in your case where is your trouble.
PetrH
I have imported the JARs from windchill 13 installation from the location of the codebase\WEB-INF\lib & codebase\lib. Still the import functions like
import wt.change2.ChangeHelper2;
import wt.change2.ChangeService2;
import wt.change2.Changeable2;
import wt.change2.WTChangeActivity2;
import wt.change2.WTChangeOrder2;
are throwing errors and not recognizable.
