Eclipse Configuration
Chanhasen
6-Contributor
Hi All,
I have configured eclipse with windchill using "ant -f bin/tools.xml eclipse_project" cmd and imported the cust_windchill_src in eclipse..
I m able to created,compile ,reload,debug java files successfully.but for jsps,xmls its not working..I have atatched the error screen shot.
is there any configuration for jsp's,actions(netmarkets,config folder) in eclipse..
Chanhasen
6 REPLIES 6
Hi Chan,
I was looking for the same thing. In the PTC Knowledge base the only reference I had was this:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS45954
For someone who is just getting into Windchill customization and jsp, however, that article leaves a lot to be desired. Basically, it tells you it is possible, but leaves lacks details and an example.
I am wondering if you ever found a better answer?
Micah
jessh
(To:Chanhasen)
I don't use Eclipse, but there's not all that much special here with Windchill.
The standard "classpath" for a JSP is dictated by the J2EE JSP and servlet specifications and boils down to <webAppDocumentBase>/WEB-INF/classes and <webAppDocumentBase>/WEB-INF/lib/*[.jar]. For taglibs, etc, there is also special handling based on what is found in WEB-INF/web.xml. Various file references are relative to the web application's document base.
In the case of Windchill, <webAppDocumentBase> is WT_HOME/codebase. This itself is at the front of the classloader lookup, rather than <webAppDocumentBase>/WEB-INF/classes. Also in 10.0 and higher, the classpath is augmented with WT_HOME/lib/*[.jar] -- and whatever else is added to the Windchill server classpath. Apart from those classpath oddities, however, Windchill just follows normal JSP/servlet development.
Hi Chanhasen
how did u get this. I tried that command but i am unable to get that cust_windchill_src in eclipse. Can you please help me.
Ram
Did you checked this document.
~Syed
Hi Syed,
I used your document. Still I am not getting the File Synchronization in eclipse. I am sharing that screens, please help me.
