Edit product subtitles (Details,Folders,Workspaces,Team..)
cdurmaz
Hello all,
I want to edit product subtitles (Details,Folders,Workspaces,Packages,Team,Tasks..)
For example, I want to change "Details" as "Detaylar".  How can I edit ?
Thanks in advance.
satre-2
(To:cdurmaz)
Below the files you need to change
For EPMDocument --> com\ptc\windchill\uwgm\util\uwgmutilResource\java
For WTDocument --> com\ptc\windchill\enterprise\doc\documentResource.java
Shreyas
6 REPLIES 6
satre-2
(To:cdurmaz)
  Labels for this actions are rendereeyasd from \Windchill\src\com\ptc\core\ui\navigationRB.java  class
You can update the Java class to change the display.
I am not  sure about language which you are using.  You can also check the  if your language is available in Language Pack.
Hope it helps !!!
Shreyas
cdurmaz
(To:satre-2)
Dear Shreyas,
I updated that folder then I restarted the Windchill but there is no any change.
satre-2
(To:cdurmaz)
After updating those files you need to compile java class and restart windchill services. You can run below command to compile java class.
ant -f bin/tools.xml class -Dclass.includes=com\ptc\core\ui\navigationRB.java
shreyas
cdurmaz
(To:satre-2)
Thanks Shreyas, it works !
cdurmaz
(To:satre-2)
Shreyas,
Do you know how to edit tabs (History, Structure, Content, Changes etc.) in info page of Documents  ?
satre-2
(To:cdurmaz)
Shreyas
