Edit upgrade request is an error
XG_9545808
2-Explorer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030
When editing the upgrade request, select the upgrade object tab, and the upgrade object table will prompt "Insufficient permissions to upgrade objects in this context", but the upgrade object is not prompted when it is created.
Translated content from Chinese to English using google translate by community moderation team.
Subject: 编辑升级请求是报错
Body: 编辑升级请求时,选择升级对象页签,升级对象表格中提示“没有足够权限升级此上下文中的对象”,但是升级对象在创建时是不提示的。
Fadel
23-Emerald I
(To:XG_9545808)
you can enable wt.access.evaluation.report to DEBUG and look in the logs for the missing permission .
Fede
