No image was attached and no logs. Please review post. Any type of SQL issues is concerning so I would have your DBA review the database and make sure things are backed up and tuned properly. From the Windchill side, recommend running so of the WinDU utilities to make sure that the integrity of the system is sound. Was there a change to the system, increase in users or a new process that was introduced?
Hi @HJ_9681957
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Not sure I did anything to solve that but thanks. Is your issue resolved? Since your image is not English, copy and paste the text of the error messages here so they can be translated. That would help other folks help you better.
